Tail Bulb Prob
Old Jul 15, 2006 | 03:57 PM
Clean98EX's Avatar
Default Tail Bulb Prob
Well we went to the movies last night and i realized that my brake lights were not working...but the running lights were! any ideas why this would be? Fuse?
Old Jul 15, 2006 | 04:45 PM
Chimera02EX's Avatar
Default RE: Tail Bulb Prob
More likely bulb burnout. Change the bulbs and see if that helps, if not then it's a wiring problem <-- difficult and time consuming.
Old Jul 15, 2006 | 05:00 PM
Clean98EX's Avatar
ok i will check the bulbs and wiring later...hopefully when it cools off...i live in central minnesota and supposed to be 101 degrees today with florida like humidity...yuck!
Old Jul 16, 2006 | 07:22 AM
land9's Avatar
when you replace the bulbs, check to see that the brake light bulbs aren't staying on constantly (faulty switch @ pedal) - burns out the bulbs in the first place
Old Jul 16, 2006 | 09:50 AM
Fiirkan's Avatar
Were your rear tail lights on when you turn the lights on? if they were then it may be a faulty brake switch behind the brake peddle
Old Jul 16, 2006 | 08:36 PM
fglaustin's Avatar
you can take a bulb and take an ohmmeter to see if it is good.
saves the time of going and buying one only to find out that it is not the problem.
Old Dec 13, 2006 | 06:33 PM
codymiles1999's Avatar
I had this exact same problem and it was just the bulb. Make sure when you check the bulb to look at it in bright light cause it can be pretty difficult to determine in the dark.
Old Dec 14, 2006 | 08:47 AM
cderalow's Avatar
holy thread revival!
2broke2smoke
May 11, 2010 03:16 PM
lowlife9
Feb 2, 2009 08:40 AM
Expando1
Mar 22, 2005 09:19 PM
spevie
Oct 30, 2004 12:32 AM
spevie
Oct 20, 2004 01:41 AM
