taking off the bumper
Old May 20, 2006 | 05:03 PM
Proto05's Avatar
Default taking off the bumper
On my 2000 Civic im trying to install foglights and im trying to figure out how to remove the bumper. I know you have to pull out the 7 pin clips but im not sure how to pull those out. Also is that all you have to do to take it off? Is putting it back on easy enough too? Thank you in advance for help
Old May 20, 2006 | 07:13 PM
shopmanual's Avatar
Default RE: taking off the bumper
I too put foglights on my 2000 LX, for the clips, if you look, there is a center and an outer piece to the clip. In the outer circle, there are two notches. If I remember right, I just took a small screw driver, and popped the center piece out. There is more hardware that's involved on the bottom. I ordered mine online from a honda dealership, and they had an installation sheet, here's the website http://www.handa-accessories.com/civ...cfoglights.pdf . That should tell you all you need to know about taking everything apart and putting it back together, especially if it's a OEM foglight kit.
Old May 20, 2006 | 08:15 PM
mill$civic's Avatar
ya along with the 7 clips at the top there are 2 bolts and 2 screws in the bottom of your bumper under the front of your car, and there are 2 screws in the wheel wells holding the bumper to the fender and thats it..it will slide off, putting it back on is super easy, just slide the bumper back on..and put all the screws and blots in..takes about 10 minits to take it off and on
Old May 20, 2006 | 11:08 PM
Proto05's Avatar
thanks for your help guys
95 Civic B16A
Feb 14, 2006 08:46 PM
Aztec007
Jun 15, 2005 04:06 PM
winka
Feb 25, 2005 08:35 PM
niteryder
Jan 22, 2005 10:35 PM
