Temperature fluctautions
Old Mar 20, 2012 | 04:27 AM
Roll Tide's Avatar
Default Temperature fluctautions
I have an 05 EX with the 1.7 vtec. A few days ago the temp would go high for a short period and drop to normal. It done this a few times. Replaced thermostat and still would go high. Replaced the radiator cap and it stayed at normal till this morning. Doing the same thing again. This time I paid a little more attention. With the temp coming up to normal I had no heat blowing out the vents. When the temp finally got within a few bars of high the heat started to blow and then temp gauge dropped. Did that a couple of cycles to make sure of what it was doing. Could it be the new thermostat is faulty? If it were a head gasket would it affect the performance of the engine? And I've seen nothing in the oil or the coolant that suggests a head gasket.
Thanks,
Steve
Old Mar 20, 2012 | 05:24 AM
dstroman's Avatar
sounds like your coolant level is low. thats usually the only reason you don't get heat coming out the vents. don't just check the overflow either make sure u check coolant level in the radiator if possible
Old Mar 20, 2012 | 06:48 AM
Roll Tide's Avatar
Thanks for the reply. The over flow is at max level. The radiator seems full. Just got back from about a 15 minute trip and the temp stayed normal. I don't know what's going on with this thing. It's kinda weird.
Old Mar 20, 2012 | 09:00 AM
Roll Tide's Avatar
Would a cooling system pressure tester tell me if it is a blown head gasket? If it leaks down and no visible external leaks then it has to be a head gasket right?
Skydiverek
Mar 15, 2006 10:43 AM
jax98civic
Feb 5, 2006 06:08 PM
jwilder
Sep 21, 2005 08:17 PM
mgm940428
Sep 7, 2005 04:57 PM
LowDown
Nov 27, 2004 01:33 AM
