timing
Old Aug 27, 2006 | 01:15 PM
stephens's Avatar
Default timing
In setting the timing on my 98 civic, the manual says to disconnect the service connection and jump the two leads. The manual specifies that this is a two-connector with a green/white and a brown wire near the engine control module. The only two connector I can find there has a blue/white and a black wire. This connector goes into the wiring harnass so I can't tell whether it goes to the ECM.
Could this possibly be the correct connector? If you check the timing with this connected, is the read inaccurate? Thanks.
smackpower
Jan 13, 2024 01:42 AM
sasquatch
May 25, 2007 04:02 PM
versitle24m
Jun 13, 2004 04:01 PM
niteryder
May 28, 2004 12:17 PM
alexander
May 19, 2004 11:07 AM
