tire change f'ked up my struts?
Old Jan 15, 2009 | 01:58 PM
mundy5's Avatar
it sure sounds like something is broken in the rear.
Old Jan 15, 2009 | 10:26 PM
madmdx's Avatar
damn the bounce seemed a lot less present for a little while today, but as i was driving back home it was doign it again...
tomorrow when my dad takes his car out of the garage ill put mine in (whre its slightly warmer than the -30, yes its been three days -30 celcius..) and lift the car. If the spring is broken im guessing its easy to tell, but where would the shock absorber be leaking fluid from?
For now my theory is the extreme cold combined with the already very old suspensions has broken something there and its just coincidental with the fact it happened when i changed my tires.
i actually thought the spring did what the shock absorber does, and vice-versa so thank god someone pointed that out to me.
I will keep you all posted when i have a look/solve the problem. who knows someone might need the info eventually.
thank you guys very much!
Old Jan 16, 2009 | 03:37 PM
Kommando's Avatar
It seems improbable, but the tires you got could have poly belts instead of steel, which would allow flat-spotting in the cold. The tires would basically be out of round, causing a bumpy ride.
I think it's more likely that your suspension components are old and tired. When the car was put on the lift, the struts fully extended as the tires drooped. Their seals may have been damaged as a direct or indirect result. This is especially likely if their shafts are dirty. The hyper-extension of components could also have caused a worn component (spring, mount, bushing, etc.) to finally let go.
Old Jan 20, 2009 | 10:30 AM
madmdx's Avatar
well a quick update for anyone interested
i didnt do anything
problem fixed itself...
:S
lol next time ill know to blame the extreme weather thanks everyone
Dylanvictor
Oct 16, 2013 06:56 AM
firecatf7333
Jan 23, 2013 11:11 AM
firecatf7333
Jul 26, 2010 12:32 PM
bigdog99
Sep 13, 2006 09:58 PM
Pete
Dec 16, 2005 09:41 PM
