Transaxle seal
Old Mar 10, 2012 | 07:07 AM
civicvtec95's Avatar
Default Transaxle seal
When replacing a transaxle seal on the left side of a 99 Honda civic vtec 1.6. Is there anything special need to do to make sure it does not leak
Old Mar 10, 2012 | 07:52 AM
First, make sure you have the correct part. The two seals are the same size but they are sensitive to the direction of rotation of the shaft, so different parts are used left vs. right. There will be an arrow on the seal showing which way the axle should rotate with the car moving forward.
When installing any seal you need to press it in evenly only on the very outside edge. Pressing in the center will bend it and it is ruined.
Check the sealing surface on the CV joint shaft. If damaged, replace it.
Apply oil or grease to the lips of the seal before installing the shaft.
Old Mar 10, 2012 | 09:15 AM
Ok the part numbers are the same for both sides at Oriely , so put a lil grease around it to put it in there
Old Mar 10, 2012 | 09:16 AM
I have had it put in before and the bottom keeps popping out
Old Mar 10, 2012 | 10:37 AM
It has to go straight in. Find a round object that is slightly smaller than the OD of the seal so when you tap on your installer, its pushing on the outside edge all the way around.
Old Mar 10, 2012 | 10:38 AM
Ok thank you
kpring
Mar 18, 2007 04:57 PM
Luke
Mar 6, 2006 04:05 PM
Luke
Mar 6, 2006 08:49 AM
aj2xz
Sep 26, 2005 07:00 PM
jwsimons
Jan 4, 2005 10:02 AM
