transmision
Old Mar 18, 2008 | 06:19 AM
redac's Avatar
Default transmision
new to civic forums & need help. i have a 1998 honda civic ex coupe with 202k miles and auto trans. my problem is when i shift from park to drive i get a double shift when trans engages, no check engine light, idle is steady at 800 rpm. anyone have same problem?
Old Mar 18, 2008 | 12:13 PM
macbeth18288's Avatar
Default RE: transmision
You posted in the wrong area.
Did you read the description that was right below the link you clicked???
"This section is for suggestions and help pertaining to the forum, not for help with a car."
Old Mar 18, 2008 | 12:18 PM
My04Civic's Avatar
Administrator
moved to a more appropriate section...
Old Mar 18, 2008 | 12:28 PM
Check the transmission fluid level. If it is low it is likely leaking from the axle seals. Change the fluid if it is more than 30,000 miles old. Use only Honda automatic transmission fluid, not a generic ATF.
Old Mar 19, 2008 | 09:29 AM
redac's Avatar
fluid level is fine. just got the car two weeks ago, dont know if fluid has been changed but i will do it this weekend, also found fluid leaking from in between trans. solenoids and distributor, dont know if it's engine oil or tranny fluid.
StarvingStudent
Apr 15, 2007 03:04 PM
justinwebb
Jan 27, 2007 10:15 AM
POLYTHING
Sep 15, 2006 02:25 PM
rlorenzen
Jul 24, 2006 05:54 AM
Super Mario
Jan 21, 2005 01:02 PM
