Trouble starting
Old Mar 8, 2012 | 07:12 AM
Rayna's Avatar
Default Trouble starting
I cannot figure out any rhyme or reason to the problems my 2000 Honda Civic is having. Every so often (spring, summer, winter) it will decide it doesn't want to start. I crank the key all the way forward and it does this consistant "rumble/shudder" and repeats this until it finally starts. It is turning over. Sometimes it seems to help if I pump the gas pedal. After about 30-45 seconds (sometimes) it slowly shudders to life. My mechanic did a full tune up checking fuel filter, starter, fuel injector, fuel pump, new spark plugs and cannot find anything wrong. Seems to happen if it sits for a day or two without running. It has happened maybe 6 times in the past 2 years.
Any ideas?
Old Mar 8, 2012 | 08:27 AM
ChristianL's Avatar
If the fuel system checks out, I'd start looking at the ignition. Since you said it does this when it's been sitting for a day or two, I'm wondering if you're getting condensation inside the distributor which isn't allowing it to pass current on to the spark plug wires.
CatsnotCars
Jan 28, 2015 12:24 PM
blkstallion
Jun 11, 2007 07:55 AM
Rainingbullets
12
Jul 21, 2006 12:44 PM
Driveracrx
Jan 2, 2006 03:44 AM
blaure
May 9, 2005 12:51 AM
