Turn signals
Old Nov 21, 2008 | 10:24 PM
B96's Avatar
B96
Default Turn signals
My self cancellation has stopped working on my 96 EX. Turn signals still work, they just don't turn off anymore when the wheel straightens out. I'm guessing its the cold weather possibly broke the tripping device on the steering column. Is this something I can fix myself? There is an airbag.
Arv
Old Nov 21, 2008 | 10:28 PM
danomatic93's Avatar
June 2010 ROTM
You'll have to replace your combination switch if you want the self canceling to work again. It's not too hard.
Old Nov 21, 2008 | 10:29 PM
ej6buddy's Avatar
6th generation civics are notorius for their cancelation turn switches. They work on and off until they finally break. The only thing to do is replace it. You need to take the panels off the steering column, but you don't need to remove the steering wheel or the airbag.
Old Nov 22, 2008 | 06:13 AM
Old Nov 22, 2008 | 09:55 AM
mundy5's Avatar
if I were you, i'd go to junk yard and pick up one for $20+. I got the wiper combination switch for $20 off of a '92 and it still works fine with my '98. so you have at least 2 generations to choose from.
Old Nov 22, 2008 | 07:07 PM
B96's Avatar
B96
Default Thanks
Gentelman thank you for your feed back. I most likey will wait for warmer weather but will follow through, including checking with the wrecking yard.
Arv
dlion77
Jan 23, 2010 09:03 AM
rzimmer11
Mar 9, 2005 09:12 PM
burnoutNshootnos
Dec 25, 2004 10:07 PM
cass4403
Dec 15, 2004 11:34 PM
Rollinon17s150
Oct 20, 2004 03:14 PM
