two questions
ok i have two questions 1st off will it hurt if my timing belt is not covered at like the bottom( and i can't get the crankshaft pulley bolt off to get to the bottom timing gear), and my tranny is stuck to the block, if i disengage the clutch then try to pull it apart will that work
thanks jonathan
thanks jonathan
Don't leave your bottom timing cover off!! You're just asking for a rock to fly in there anf f**k your s**t up.
And the bell housing has two straight plugs (much like the head) that slide into the block. These may be stuck or rusted, so once you're sure all the bolts are out of the bell housing, try prying gently with a large screwdriver.
NIKE H34D
Sep 2, 2012 01:17 PM
THansen
Aug 13, 2006 10:28 PM
