Vacuum Dashpot questions
Old Oct 7, 2007 | 08:08 PM
SirTealingstonThe2ND's Avatar
Default Vacuum Dashpot questions
I have a 91 civic with a SOHC ZC swap in it, I recently purchased a new engine that I am going to build and put in at a later time. My current engine has failed the e-test and I noticed on the new engine (a DOHC ZC) it has what is called a Vacuum Dashpot or Vacuume Throttle Control, I was wondering if the SOHC throttle body needed this, the 2 throttle bodies differ slightly, but on the SOHC throttle body there is a spot for the Vacuum Dashpot.
Also I am worried because there is a vacuum line coming out of theleft side (when facing the front of the car directly) that has a screw on it to block out air... I will upload pictures as soon as I take them, could these things ruin an e-test? It failed in the NO ppm, the limit is just over 800 I scored over 2500
Old Oct 8, 2007 | 05:56 AM
foress_89's Avatar
Default RE: Vacuum Dashpot questions
I couldn't tell but a vaccum line blocked buy a screw is not a good thing... vaccums are there for a reason! You should find out where it is suposed to go and put a new line.
Old Oct 8, 2007 | 09:14 AM
Does anyone have a vacuum hose diagram??
Old Oct 8, 2007 | 09:18 AM
Heres the pictures, im sure something is wrong, I am going to hook up the Dashpot and try and figure out the vacuum hoses, any help would be great!
Old Oct 8, 2007 | 09:28 AM
foress_89's Avatar
I have the manual on my comp.. but I can't seem to find out the section about vaccums. It's 16mb, PM me so we can figure out a way of sending it to you.
Old Oct 8, 2007 | 11:03 AM
Or, does anyone have any pictures of their engine area around the throttle body area where the vacuum lines are? For a 1.6L stock honda engine or SOHC ZC
bcrichguitars
Oct 15, 2008 06:32 PM
1997civic
Oct 21, 2007 01:29 PM
oldguy
Mar 17, 2007 01:03 PM
xonic
May 26, 2005 04:58 PM
civic9988
Oct 24, 2004 07:22 PM
