valve adjustment
I just did that valve lash adjsuments last week.
Not that hard just keep double checking your clearance.
all 95 d15's and D16z6 .007-.009 intake side
.009-.011 exhaust side
95 B16a3 .006-.007 intake
.007-.008 exhaust
.007-.008 exhaust
do you need to buy a new valve cover gasket before pop the cover off, or can you re-use the existing gasket?
interesting: when peeking thru the oil filler cap hole in the top of the valve cover, the rocker adjustment screws look just like the ones on my XR50 mini bike. could it be that they function the same way?
I reused the valve cover gasket when i did it.
but its better to get a new one just in case, you can order them at autozone for $10, takes about a day.
Thats for the valve cover set.
You need also a feeler guage.
17 mm for the crank pulley nut to turn it.
