valve adjustment
Old Dec 17, 2007 | 11:47 AM
blackmetal619's Avatar
Default valve adjustment
when doing a valve adjustment,does it involve the distributor at all?
Old Dec 17, 2007 | 12:21 PM
Default RE: valve adjustment
No, I don't think so (see pictures for 96-00 Civics).
Old Dec 17, 2007 | 01:02 PM
ok thanks. i just did a valve adjustment but it didnt solve my knocking noise.
The idle is fine and doest fluctuate, but the noise the engine is making comes and goes but it constantly taps.
It sounds like its coming from the bottom end.
any ideas?
Old Dec 17, 2007 | 01:14 PM
Check that the sheet metal cover plate on the very bottom isn't hitting the flywheel, or maybe a bad motor mount.
If it really is inside the engine, low pitched knocking from the bottom of the engine is ominous, means the bearings are shot. Typically this results from running out of oil or never changing the oil and getting sludge buildup. You can try using heavier oil but likely you're going to need a new engine soon.
Old Dec 17, 2007 | 01:18 PM
mxs's Avatar
mxs
ORIGINAL: blackmetal619
any ideas?
Engine Noise Diagnosis 101
http://remanufactured-engines.com/page4.htm
Old Dec 17, 2007 | 01:20 PM
could it be piston slap?
Old Dec 17, 2007 | 01:24 PM
thanks for the link.
ill see what i can do
after reading through the link, i think it could be piston slap now.
how can this be fixed, or is my motor just shot?
Old Dec 17, 2007 | 01:48 PM
honda_farmboy's Avatar
Banned
i have a low pitched knocking noise too. i don't think it's the same engine. i never really noticed it before i unsucsessfully tried to remove the crank bolt (lots of torque applied by holding the flywheel with a screw driver) i'm thinking i MAY have a cracked flex plate but not sure. took off the inspection plate and everything is fine from what i can see. took both bolts off the motor mount but the noise is still the same, even when jacking up the engine and putting tension on some of the other mounts. it doesn't sound like it's in the crankshaft though. it seems like the noise is on the top of the engine.
Old Dec 18, 2007 | 12:05 AM
extreme's Avatar
could be a worn camshaft. do these have hydraulic tappets/lifters/buckets or what ever you call them?
Old Dec 18, 2007 | 06:37 AM
No they don't have hydraulic lifters, that's why you have to adjust the valve clearance manually once in a while to compensate for wear.
viciv
Dec 15, 2006 02:23 PM
mig25
Nov 17, 2006 12:39 PM
KC4
Jun 24, 2006 02:23 AM
97civicturbo
Jan 15, 2006 12:40 AM
troutman
Nov 19, 2004 05:47 PM
