Valve adjustment
Old Jul 3, 2009 | 10:22 AM
conceptualpolymer's Avatar
Default Valve adjustment
Anyone adjust or had your valves adjusted? If so, how many miles were on your Civic at the time? I'm hearing that over time, the valves get a bit noisy and need to be adjusted.
Old Jul 3, 2009 | 10:52 AM
It's a relatively straightforward job. Remove the valve cover and upper timing belt cover. Turn the crank to TDC1, 2, 3, or 4 to adjust the intake and exhaust valves using a feeler gauge. If your 97 Civic has never had a valve job, then now is a good time to do it.
Old Jul 3, 2009 | 12:22 PM
Thanks. How often would you say the valves need to be adjusted? I have a bit over 120,000 miles on my Civic.
Old Jul 3, 2009 | 12:52 PM
In my opinion, checking the valve clearance every 30K miles would be a good idea.
viciv
Dec 15, 2006 02:23 PM
mig25
Nov 17, 2006 12:39 PM
KC4
Jun 24, 2006 02:23 AM
97civicturbo
Jan 15, 2006 12:40 AM
troutman
Nov 19, 2004 05:47 PM
