Is this a vtec??
Old Jun 6, 2012 | 02:53 PM
95civic00's Avatar
Default Is this a vtec??
1.5l l4 sohc 16v
Old Jun 6, 2012 | 03:02 PM
Unless it's a JDM D15B, it's probably non-vtec.
Old Jun 6, 2012 | 03:07 PM
95civic00's Avatar
Thanks, how do I find out if it is JDM D15B?
Old Jun 6, 2012 | 03:27 PM
There is a plate on the front of the engine to the left of the exhaust manifold that will say the engine code.
Old Jun 6, 2012 | 05:04 PM
95civic00's Avatar
Great Thanks!!
Old Jun 6, 2012 | 07:33 PM
The stock 1.5 in a 95 was non-VTEC. 92-95 EX's had a 1.6 liter. You can spot the non-VTEC D15B2 / D15B7 instantly because they have the spark plug holes on the intake side of the valve cover, toward the back of the car. If the spark plug holes are on the exhaust side, toward the front of the car, the head is possibly VTEC. In that case, look for a VTEC solenoid on the back of the head near cylinder 4.
The number on the block doesn't tell the whole story because the SOHC heads interchange readily, so someone could have swapped on a head that didn't originally come with your block. The VTEC system is all built into the head. The block just sets the cc displacement.
Old Jun 7, 2012 | 02:05 PM
95civic00's Avatar
Awesome! Its not a VT now ive gathered from that information. No big deal... I just want to figure out why it shifts at extremely high RPMs and no one seem to know...
Old Jun 7, 2012 | 03:48 PM
zerojett's Avatar
it's a honda. power its made through rpm and torque. torque is made primarily with displacement. honda made up for the lack of displacement with a high redline.
Old Jun 8, 2012 | 05:13 AM
The automatic is designed to shift at higher rpms when you have the gas pedal floored, and lower if you (try to) accelerate without flooring it.
Booger
EK Swaps
Aug 9, 2011 10:11 PM
88civicjordan
Mar 2, 2006 09:12 PM
ryantann
Feb 21, 2006 09:50 PM
mahmi
Aug 25, 2005 09:39 AM
kcmercedes
EK Swaps
Sep 24, 2004 11:05 PM
