Weird noise while turning
Old Oct 23, 2007 | 09:36 PM
Shbek's Avatar
Default Weird noise while turning
Over the past week I've noticed a clicking noise from the front right tire whenever I'm turning left and have my foot on the gas. It sounds pretty bad.
If I turn without using the gas, no clicking, if I brake while turning, no clicking. If I turnright, no clicking. Its just when I turn left and accelerate. Any ideas as to what it could be?
Old Oct 23, 2007 | 09:39 PM
danomatic93's Avatar
June 2010 ROTM
Default RE: Weird noise while turning
could be a CV joint, bad bushing, or loose bolts
Old Oct 23, 2007 | 10:36 PM
Civic Si 00's Avatar
More likely your right axle is going bad.. That is the 1st sign,,,, the clicking sound..If that is the problem I recommend you replace both sides already..
Old Oct 24, 2007 | 05:53 AM
Shbek's Avatar
Is the axle being bad even possible? Its a 98 coupe with just over 100,000 miles on it... I treat it like a baby and it was owned by a middle aged lady before me and I seriously doubt she treated it badly. Anyway I can check it without taking it to the shop? Like will there be visible signs of wear? If so what would that look like?
Lil tight on cash right now....
Old Oct 24, 2007 | 06:52 AM
93civicSI99's Avatar
check out the cv shaft, i had the same problem.
Old Oct 24, 2007 | 07:03 AM
cderalow's Avatar
chances are, you'll find a blown CV joint on that side, most likely the outer CV joint.
The inside of your wheel, will be greasy.
You're better off just getting the axle changed if this is the case
puddyguy
Oct 23, 2014 02:23 PM
bank5
Jul 4, 2010 11:33 AM
vex_helix
Nov 15, 2009 10:18 PM
DNkG
Jun 8, 2009 12:34 PM
ryanhoangle
Jun 26, 2008 02:51 PM
