Scraping noise from the rear while turning right??
Old Jun 4, 2009 | 04:02 PM
DNkG's Avatar
Default Scraping noise from the rear while turning right??
Hi guys, im getting a grinding/scraping noise from the back right of the car when taking right turns. Also it seems like something is loose in that area when the car hits bumps. Could it be the back sway bar? Any suggestions, Thanks.
Old Jun 4, 2009 | 04:29 PM
Check your bushings for excessive wear, and get under the car and just look for anything that you can possible shake to create noise.
Old Jun 4, 2009 | 04:47 PM
Note that while you are turning right, there is more stress on the left wheels. It may be helpful to drive past someone standing outside the car while they listen to try and localize the noise.
Old Jun 5, 2009 | 04:01 PM
DNkG's Avatar
I brought it into the mechanic today and he said it was just dirt in the wheel she still makes the noise. He also said the car has "lazy" shifts which he is going to try to fix monday by using lucus and hopefully fixing the oel light which he thinks is an o2 sensor. Around how much should this sensor run me if that is the case? This car has been nothing but a headache, mainly the stereo
Old Jun 5, 2009 | 04:05 PM
kanarrjl's Avatar
if the CEL is on and its an o2 sensor it could be up to $120 for the sensor plus his install cost (probably around $35)
Old Jun 8, 2009 | 12:34 PM
DNkG's Avatar
Yea he replaced both of the sensors. One costed $210 Canadian and the other 140. Does this seem right? and also do you think that it was necessary to get them replaced. Honestly i would have sooner saved 500 bucks if it wasnt going to seriously hurt anything? thanks guys
vex_helix
Nov 15, 2009 10:18 PM
HyundaiCivic
Sep 18, 2008 01:41 AM
ChicagoCivic25
Jul 30, 2008 06:41 AM
ryanhoangle
Jun 26, 2008 02:51 PM
Shbek
Oct 24, 2007 07:03 AM
