Weird TPS problem..
Old Oct 1, 2012 | 08:20 AM
FantmClwd's Avatar
Default Weird TPS problem..1997 honda civic ex
I have looked at the other Throttle Position Sensor threads and none are like mine, so hopefully someone can relate or know what to do.
I have a 1997 Honda Civic EX and almost 4 months ago I started getting spiking rpms while driving and a high idle at 2k, note that it wouldn't do this every day, it was like a hit or miss kind of thing. I had a CEL so I got codes pulled and it called for a TPS problem. So I bought a new tps and my buddy put it on and calibrated it to 4.5 and 0.5, after that everything has been completely fine. Then a week ago it all started again, except the high idle. This time though the rpms would go up a slight bit then down at a fast rate till i gave it more gas to push it through. The engine light came back on and I pulled the same code for the tps. Replaced the TPS, calibrated, perfectly fine. NOW it has messed up AGAIN, same code as well. But so far it hasn't had the rpm spiking problem it just takes a bit of higher rpms to shift and when I drop it from park to rev, d4, d3, d2 it jerks the car hard..So I'm thinking it could be a faulty wire somewhere causing it to mess up every now and then and not all the time? I would think that if it was the TPS it would be a constant thing. That is the suggestions I have been getting. Any ideas?
Old Oct 6, 2012 | 08:06 AM
FantmClwd's Avatar
anyone? This is really important to me, i love my car and I dont want to drive it in this condition.
Old Dec 15, 2012 | 01:16 AM
TS1's Avatar
TS1
Default TPS Problem
I have a very similar problem. Did u manage to figure it out?
savya2u
May 27, 2008 10:30 AM
pcgmr
Sep 3, 2006 09:36 PM
ef4life
ED-EF Swaps
16
Jan 25, 2006 04:51 PM
cmasonrun
Jan 12, 2006 11:25 PM
fast93civic
Jun 11, 2005 10:19 PM
