Weird ware on tires
I have a 92 honda civic sedan.the tirs on the car rims or factory,them seem to ware on the inside of the tire.The inside of the tire goes to steel and the outside is ok.I think that it needs a alinment,does it sound like it and if so how much does this run normaly.[&:]
you will generally run into about 45 bucks for a rear WHelel drive and 55 fr a front wheel drive and 65 for an AWD vehicle. also it could be your tire pressure as well. but then i think it would be i the outsides of the tires. and it could also be that you don't rotate and balance your tires as oft as ye should.
its a camber problem. civics dont have any adjustment for camber stock, so you need to buy camber kits. you can also just get the toe set at 0 and it will help a lot, but a camber kit will help it even more. and i mean 0, not "in spec"
soafed
Nov 25, 2008 01:17 PM
natecivic92
Jun 4, 2007 07:00 PM
bloohatch
Jul 23, 2005 10:05 PM
