What can make a crank position sensor go bad?
Old Dec 11, 2010 | 07:34 PM
JPB's Avatar
JPB
Default What can make a crank position sensor go bad?
Hi,
Have a 2002 Civic w/100K miles. Have been delighted w/performance. No major troubles, ever. What a great car!
Can this sensor go bad just out of the blue? Problems started 50 miles after the 100K service which included timing belt change. Coincidence?
Thanks,
JB
Old Dec 12, 2010 | 12:29 AM
yup, they just go bad, ive just had to replace one on my jeep also
Old Dec 12, 2010 | 07:59 AM
maachan513's Avatar
Timing belt change job may have required to remove the sensor. The sensor was put back but not tight enough and moved out of adjustment to pick-up signal from the crank.
Old Dec 12, 2010 | 08:25 AM
Or the sensor wires got pinched or caught in the belts or pulleys.
Or the sensor just quit by coincidence. The Jeep ones are notorious for that (if you have a late 90s Jeep that won't start, 10:1 it's the crank sensor). Honda not so much.
Old Dec 12, 2010 | 09:53 AM
JPB's Avatar
JPB
Many thanks for your replies. Here's a follow-on question. Does a sensor that is going bad exhibit symptoms over time, or is it just *boom* one minute it's fine, the next, the car is lurching.
(Can you tell I'm trying to consider what to discuss with the mechanics? A huge bill for the 100K/timing belt, etc. service followed by another large bill within 2-3 days doesn't sit well! If we hadn't had another problem recently where we gave benefit of the doubt, I wouldn't be in such a quandary.)
JB
Old Dec 12, 2010 | 10:41 AM
maachan513's Avatar
I don't have enough experience on the subject so I am guessing that if the sensor is loose but not that loose and is in the threshold of picking up the signal,,,,. what you are seeing maybe possible,,,.
Old Dec 12, 2010 | 11:26 AM
99lx's Avatar
JB
I think it's pretty much luck of the draw with regard to sensors. On most vehicle's I've owned, sensors have been fine one day and completely crapped out the day after.
Old Dec 12, 2010 | 12:35 PM
It's like that with most electronic parts. Work perfectly their whole life until suddenly they... don't.
denisholden
Mar 24, 2013 05:15 AM
fancygirl68
Apr 19, 2010 07:57 AM
Red_Neck
Mar 22, 2007 12:35 PM
Mario89
Nov 27, 2006 09:31 PM
joshr799
Mar 22, 2006 08:53 PM
