what could be my problem
i got my headers, test pipe, and exhuast put on and my car sounded and ran great. when vtec kicked in it ripped.... sounded so good. Then my check engine light came on and the crossover wasnt there anymore. The computer says that my 2nd o2 sensor is bad.... anyone know where i can get a dumby o2 sensor or an advaced one for cheep. i think this will solve my problem
The problem is definitely the test pipe. It's not a real cat, so the o2 sensor readings wont be right. Hence the check engine light. When you have a check engine light, the car is put in limp mode. Vtec is disabled.
I'd put a real, quality hi-flow cat on there to save the environment. It's probably better for your mpg to have the computer calculating actual figures, not dummy numbers.
Failing that, there are dummy o2 sensors out there. I wouldn't know where to get them.
Thanks for the help... i got my car checked and 4 codes came up.... all on the 2nd o2 sensor and cat.... i got a part for my back o2 sensor sorta like a dumby part... they said it would fix my problem... thanks again
and it makes your car sound like garbage.... i would suggest putting a cat its not expensive at all or hard to install
Tricking your car with dummy o2 sensor is kinda stupid i think
billharryeobd2
May 3, 2020 08:54 AM
My04Civic
Dec 15, 2008 07:05 AM
forcefedcivic27
Sep 12, 2004 08:06 PM
