What determines air/fuel ratio on a 1991 honda civic?
Old Apr 11, 2010 | 06:16 PM
lynkite's Avatar
Default What determines air/fuel ratio on a 1991 honda civic?
So i figured out I have a 1991 engine sitting in my 1994 chassis. I'm getting really bad MPG, like 150 to the tank. What else, besides the O2 sensor regulates the fuel/air mixture? I can smell that it's running rich. I overheard someone talking about the coolant temp sensor has something to do with it. Is this true? Any suggestions to fix this problem?
Old Apr 11, 2010 | 07:53 PM
Are you running an OBD0 or OBD1 ECU? But both should be similar - A/F ratio is determined by the ECU, which takes inputs from multiple sensors, including MAP, O2, ECT, IAT, TPS, etc.
Any CEL codes? Is the thermostat stuck open? Is there an exhaust leak? Is the fuel pressure high? Is a fuel injector stuck open?
Old Apr 11, 2010 | 09:49 PM
lynkite's Avatar
there is no map on a 1991 honda engine. IACV replaced. TPS good.
Old Apr 12, 2010 | 04:47 AM
My stock 1991 has a MAP mounted on the firewall. Please don't start new threads about the same problem.
B!@ckBoYwiTaC!v!c
Feb 1, 2007 08:52 AM
BGFastCivic
Nov 15, 2006 08:13 AM
96civic285whp
Jun 16, 2006 10:04 PM
lilpooh21186
Mar 15, 2006 07:52 PM
red_sleeper
Jan 26, 2005 06:51 PM
