What may be wrong with my signal light?
I have a Honda Civic LX 2000 and suddenly the driver signal light stopped working. I changed the bulb light and still not working, I check the fuse box and everything is OK. but the other day I was driving and i turn on the signal and it was working. When I started the car again the signal light was not working again. does somebody have any idea of what is going on? by the way, this problem is only with the front signal light on the driver side.
Check the socket for rust. Take the socket out of the housing and wiggle it around while leaving the signal on to see if there is a loose connection.
Starting and stopping the engine doesn't have anything to do with the turn signal system. They should work whenever the key is on, whether the engine is running or not.
Jack Brush
Apr 28, 2012 05:33 AM
the_crippler011
Feb 6, 2008 12:00 AM
jbum
Oct 13, 2006 02:44 PM
