what will i have to do to make this motor work
92-96 JDM H22A 2.2L DOHC VTEC 200HP ENGINE 5SPD TRANSMISSION ECU JDM H22A COMPLETE SWAP HONDA PRELUDE ACCORD 5SPD TRANS + ECU [H22AMTE] - $2,000.00 : got-jdm.com, JDM Imported Engines, Performance Auto Parts at Wholesale Prices
this are the specs and what it comes with
JDM H22A DOHC VTEC HONDA PRELUDE / ACCORD ENGINE SPECS:
Donor Vehicle: JDM 92-96 Honda Prelude BB4
Mileage: 25k-45k miles
Displacement: 2157cc
Valve train: 4 Cylinder, DOHC VTEC, 16 Valve
Horsepower: 200 HP @ 6800 RPM
Torque: 161 LBS-FT @ 5500 RPM
Fuel Control: OBD-1
Compression: 10.6:1
Bore: 87.0mm
Stroke: 90.7mm
Redline: 7200rpm
INCLUDED PARTS:
- 5SPD FWD Hydraulic Transmission
- P13 DOHC VTEC ECU
- 100% Complete Engine
-Complete Block
- Complete Head
- Intake Manifold
- Engine Wiring Harness
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Throttle Body
- Alternator
- Starter
- Half shaft
- Pulleys
- Ignition Wires
- A/C Compressor
- Power Steering Pump
Fuel Control: OBD-1
Compression: 10.6:1
Bore: 87.0mm
Stroke: 90.7mm
Redline: 7200rpm
INCLUDED PARTS:
- P13 DOHC VTEC ECU
-Complete Block
- Complete Head
- Intake Manifold
- Sensors
- Exhaust Manifold
- Fuel Rail
- Injectors
- Distributor
- Throttle Body
- Alternator
- Starter
- Half shaft
- Pulleys
- Ignition Wires
- A/C Compressor
**Alan**
28
Jan 29, 2008 06:41 PM
97b16swapcoup
Mar 21, 2005 08:32 PM
