V-TEC HOW TO MAKE IT WORK?????
Old May 2, 2006 | 03:33 PM
civicblend97's Avatar
Default V-TEC HOW TO MAKE IT WORK?????
i have a 97 civic with a d16y7, and i have a d16z6 head to put on it. but how do i get the v-tec to work the car still has to pass inspection?
at first i thought i could just use a v-tec controller now i have read and found that does not work.
is there any way to make it work without changing ecu?
if not could i use a y8 ecu i have to keep it OBD2?
Old May 2, 2006 | 03:49 PM
jwsimons's Avatar
Default RE: V-TEC HOW TO MAKE IT WORK?????
p72 is obd2 with vtec
Old Aug 11, 2007 | 07:40 AM
defjamon22z's Avatar
where do u get p72 ecu from?
Old Aug 12, 2007 | 05:39 PM
t34me's Avatar
ebay, junkyard, your buddys car, honda......
Old Aug 13, 2007 | 07:53 AM
SovXietday's Avatar
ORIGINAL: civicblend97
1) at first i thought i could just use a v-tec controller now i have read and found that does not work.
2) is there any way to make it work without changing ecu?
3) if not could i use a y8 ecu i have to keep it OBD2?
1) No
2) No
3) No
You'll need a Y8 head and a P2P ECU if you want to keep it OBD2. Otherwise you'll need to convert to OBD1 and run a P28.
Old Aug 17, 2007 | 12:02 PM
point break 92's Avatar
lmao, no no no
Old Aug 19, 2007 | 02:27 PM
bcrichguitars's Avatar
This got me worrying a bit. I have a P06 chipped for Uberdata on my 95 turbo civic. I have a JDM d15b vtec, does my ECU even allow my vtec to kick in?
Old Aug 19, 2007 | 06:43 PM
gsumano's Avatar
ORIGINAL: bcrichguitars
you need to mod your p06 into a p28. You just basically need to add some resistors, they sell kits online that come with everything thats needs to be solder in order to be a p28.
Old Aug 31, 2007 | 10:57 PM
hellbent87's Avatar
okay so me and my buddy both got civics. mines a 6th gen with tha stock d16. his is a 5th gen with tha same motor i believe. anyway mine was always faster than his until recently when he met some dudes who did somthin wit his vtec celenoid. now he smokes me every time! i need to kno what did they do, how did they do it, is it bad for his car, can i do that to mine?
HondaEGcoupe
Aug 9, 2009 10:12 AM
Kenneth Ames
20
Feb 17, 2007 10:39 AM
gunmetal
Jul 18, 2005 08:37 PM
AOL.COM
Apr 24, 2005 12:07 AM
lilol89crx
Jul 29, 2004 06:56 PM
