Whats wrong with it
Old May 1, 2007 | 01:28 PM
BlackedOutCiViC's Avatar
Default Whats wrong with it
Ok, After getting an intake, and Header put on (the rest of the exhaust isn't on yet) I started up my car. Before the idle was fine, After Connecting the **** back together again, when I turn the car on the Idle goes up and down, and I dont mean like 100-200 RPMs, It sounds like around 1000 RPM jump, Then after a few seconds the RPMS sound like it's redlineing. By then I turn the car off not to make it heat up too much. Anyone know what causes that?
Old May 1, 2007 | 02:44 PM
Chimera02EX's Avatar
Default RE: Whats wrong with it
Vacuum leak. Check to make sure everything is nice and tight.
Old May 1, 2007 | 03:18 PM
cderalow's Avatar
check that you didn't accidentally put something against the throttle arm while installing the intake...
Old May 1, 2007 | 05:03 PM
I havn't checked the Vacum lines yet, so I'll look at them. And I'll check out what all my CAI is next to for that. Thanks for the responses, I really wanna get this car going good.
Old May 1, 2007 | 08:47 PM
that guy's Avatar
also, make sure to reset the ECU after you get those vac lines figured out. that will let your engine adjust for the extra airflow coming in and out.
pull the negative battery terminal for about 30 seconds. then put it back on. turn your car on and let it sit for fifteen minutes solid where you do NOTHING TO IT (NO REVS OR RADIO...etc). then turn it off all the way, remove the key. start it up immediately thereafter and you're good to go.
don't do this if your car is still going nuts and redlining like a sumb!tch
Old May 2, 2007 | 07:31 AM
Check to make sure you didnt disconnect or damage your TPS
Old May 2, 2007 | 08:23 AM
phan10m's Avatar
this is why im afraid to do the stuff myself
Old May 2, 2007 | 10:35 AM
that guy's Avatar
^you learn HOW to do this kind of stuff from people like Forty04, who take time out of their own lives to help people like us. pay attention to him and the rest. they're happy to help.
BlackedOut, try to get some pics of how you installed it. That might help us see the problem. Hopefully, it's something simple for you.
Old May 2, 2007 | 05:43 PM
ORIGINAL: Chimera02EX
He is right, I forgot about the line not being connected, well not even there. So I gotta get the local Civic Expert to help me lol. I call him that cause thats his thing, hes got a sick little hatch, not one thing you can say is ricy on it. He also has a shop and a bunch of parts. But thank you all for the help. Thats one reason why I joined, to be more knowledgable, and to get the help needed. So again, Thanks guys.
rice_patrol
Mar 16, 2006 09:45 AM
Remmy
Dec 27, 2005 09:18 AM
igaryy
Dec 12, 2005 12:03 PM
hcwrecker83
Jul 31, 2005 08:38 PM
killatacticz
Jul 21, 2005 09:58 PM
