Wheel bearing??
Old Mar 16, 2011 | 11:38 PM
EK_MaGz88's Avatar
Default Wheel bearing??
Wussup everyone. I drive a 98 civic hatch and recently i've noticed a high pitched squeak that comes from the front driver side tire. If i keep driving it later turns into a "metal rubbing" sound. The sound gets louder when i turn the wheel to the left, but only while the car is in motion. It does not make noise if the car is at a stand still whether i turn the wheel or not. I have not noticed any unusual shaking in the steering wheel. What do you think this can be?
Old Mar 17, 2011 | 03:31 AM
Mecca8383's Avatar
Take off the Driver side wheel & look for any metal shavings, look for spots that appear scraped inside the wheel & all around the brake area.
Old Mar 17, 2011 | 11:36 AM
Does the noise change / go away when you step on the brakes lightly? If so it is probably the squeaker spring telling you that the brake pads are worn out.
Another common noise from a front wheel involves the sheet metal behind the brake rotor getting rusted or bent and dragging on the rotor. Noise from a wheel bearing is more of a constant roar that is proportional to speed and gets worse when you turn away from the affected side (because the weight of the car shifts to the outside of a turn, putting more weight on the bad bearing.)
darkangrydragon
Apr 3, 2012 01:37 PM
beloveddoll
Dec 27, 2006 03:38 PM
supradupra
Nov 9, 2006 10:13 AM
POIZN
Jun 24, 2006 10:45 AM
95CIVICUS
Dec 25, 2005 11:18 AM
