WHEEL SIZE???
Old Sep 16, 2006 | 10:49 AM
megafandrew's Avatar
Default WHEEL SIZE???
hey guys, i want to put some winter rims on my 2002 honda civic, do u guys know what size they need to be, I know its a 4 bolt pattern and 15 inch rim, but i was looking at the winter rims and they have a demension like this (16*5, 5-4-1/4) What does that last part mean (5-4-1/4)????
Old Sep 16, 2006 | 10:02 PM
fglaustin's Avatar
Default RE: WHEEL SIZE???
thought that metric was used in the last number you have.
like 100 mm, which is 2.54 inches, or that is to say 2 1/2.
you got 16 x 5 where the 5 is wheel width (measured across the wheel barrel from the front rim to the rear rim) and the next 5 is the number of bolts (or lugs) and then i think you got 4 1/4 inches which is the distance between the center of the two lugs taken across the center of the wheel.
the 16 is of course the wheel diameter (size of the wheel measured across its center).
Old Sep 16, 2006 | 10:07 PM
Chimera02EX's Avatar
Stock steelies FTW for winter driving.
Old Sep 17, 2006 | 09:21 PM
Ok, that straightens out the dimension part, but my car does not have the stock steel wheels included, so i need to purchase them, i can use the aluminum wheels i have for the dimensions right? They are 15 inch 4 bolt wheels.
Old Sep 18, 2006 | 12:20 PM
fglaustin's Avatar
if those alum work, then the steel will also.
wonder why you do not want the alum rims ?
Old Sep 19, 2006 | 10:35 PM
can u use aluminum wheels in winter???
Old Sep 20, 2006 | 08:23 AM
fglaustin's Avatar
i've seen them in north dakota at 64 below zero.
are you where it gets colder than that ?????
Old Sep 20, 2006 | 09:26 AM
ef4life's Avatar
just go to a junkyard an look for a old honda and jack the rims (only civics and integras). the stock honda wheels are pretty narrow which is good for snow.
or if you want a wider wheel, all saturn s series and 03-04 ions used the same 4x100 lug pattern, and they came in 14x5.5 and 14x6 steel wheels or 15x6 steel to put a wider tire on them
Old Sep 30, 2006 | 06:15 PM
ok, and it doesnt really get colder than 64 so i should be okay
z6 FoRiLLa
Sep 15, 2005 04:28 PM
Rweasel6
Apr 20, 2005 04:51 PM
INJENalltheway
Dec 28, 2004 08:06 PM
CivicCrazy
Dec 1, 2004 09:21 PM
zaidomar
Nov 17, 2004 01:06 PM
