Mechanical Problems & Technical ChatIf you've got a problem you just can't figure out, a noise you can't diagnose, or a check engine light that won't go away, ask about it here!
2014 Civic, There is some sort of a gasket / rubber seal between the body and the window trim that has deteriorated and looks bad. Can I scrape that out and squeeze in some black silicone? Thanks.
