wont start after head gasket replacement.
Old Mar 15, 2006 | 10:05 AM
lvo civic's Avatar
Default wont start after head gasket replacement.
hi . just got done replacing a head gasket. mechanical part was not difficult. car will not start. it cranks but no start. how do i check if i am getting spark. i don't suspect fuel problems since i did not have any before. thanks.
Old Mar 15, 2006 | 10:37 AM
Street Sniper's Avatar
Default RE: wont start after head gasket replacement.
Welcome.
Did you check all of your connections? I forgot to reconnect my distributor last time I cahnged it and it took me 5 minutes to figure it out.
Old Mar 15, 2006 | 10:43 AM
lvo civic's Avatar
yes i just got done checking connections. the car seems to want to start. it actually does with very low power. idles for a few seconds then it dies. does this mean i got a timing problem. thanks for your help.
Old Mar 15, 2006 | 10:45 AM
Even if the timing was waaaay jacked up, it would still start, it would just run like ***. You may be off a tooth or two on your timing belt. That would suck.
Old Mar 15, 2006 | 10:50 AM
lvo civic's Avatar
if i was off on my timing belt is there a shortcut or just taking all apart and realign.
Old Mar 15, 2006 | 11:43 AM
blksiracer's Avatar
take it to someone that knows what they are doing before you really f up your motor!
Old Mar 16, 2006 | 12:43 AM
patcheway's Avatar
your timing is probably off you do have to take the belt back off or move your plug wires up one or back one and try that
bmccue1964
Apr 2, 2015 04:25 AM
jpking17
May 26, 2014 11:31 AM
martinc98
Dec 6, 2013 07:30 AM
dylank
Aug 7, 2013 07:59 AM
slade8
Dec 6, 2009 06:23 PM
