won't turn in cold
Old Jan 14, 2007 | 10:16 AM
lintondoza's Avatar
Default won't turn in cold
Right, so my car doesn't like to start in the cold. I'm getting electrical power to the accessories, but the starter doesn't crank. My guess is that either starter is wearing out, or there is something wrong with the wire/connection that tells the car my clutch pedal is depressed? is there anything i can do to remedy this other than hitting the starter with a wrench to move the selenoid? i know i probably need to replace the starter, but if that's the problem, i'll wait till it is warm enough to start and drive it to get a replacement. Also, the battery terminals and negative ground have been cleaned.
Old Jan 15, 2007 | 04:40 PM
lintondoza's Avatar
Default RE: won't turn in cold
i'm bumping this thread and adding info. my civic is a 1998 dx coupe.
Old Jan 15, 2007 | 04:50 PM
AgentofDarkness's Avatar
Have the battery tested. FInd some place that does conductance tests b/c they are better than load tests.
Old Jan 16, 2007 | 12:24 AM
TheMoogly's Avatar
Maybe your gas line is frozen? Have you tried that fuel additive/de-icer stuff?
Old Jan 16, 2007 | 11:10 AM
ORIGINAL: TheMoogly
How would a frozen gas line cause the starter to not crank over?
Old Jan 16, 2007 | 12:42 PM
brokenarmboy19's Avatar
uhm no it would need to be below -80f
edit for spelling
dlion77
Jan 23, 2010 09:03 AM
lissy983
Jul 31, 2005 09:55 AM
lissy983
Jul 29, 2005 09:34 AM
ollie
May 6, 2005 10:18 PM
93civiccoupe
Feb 20, 2005 05:52 PM
