can anyone define turbo stats for me?
Old May 18, 2007 | 09:38 AM
jobey's Avatar
Default can anyone define turbo stats for me?
ok i have a t3 t4 63 AR 57 trim
and a t3 t4 .50/.84
what one is bigger and spools faster.. what not.. i need to know what this all means
Old May 20, 2007 | 04:23 PM
MY99SI's Avatar
Default RE: can anyone define turbo stats for me?
the .84 exhaust housing is going to take alot longer to spool compaird to the the 57 trim .63A/R
the .63 will spool on a b16 around 3500-4K rpm and be producing full boost around there also.
the .84 will be able to flow more air, and be able to make more power on the top end. but it'll take ALOT longer to spool... 5-6K i would say to hit full boost.
i would suggest the smaller turbo for a stock motor setup.. then go to the bigger .84 exhaust sideed turbo for a built motor
Old May 20, 2007 | 04:48 PM
FlipHKD720's Avatar
is your car gonna be your daily driver? A lower spooling turbo will put you into boost faster and might not be very good for mpg, but if its your driver around town in the city you'll feel the power more than a higher spooling turbo that takes longer to put you into boost
Old May 26, 2007 | 05:38 PM
jobey's Avatar
this is a CRX with a 2.2 prelude swap its a g/f of mines car
she is getting jerked around by some guys at a shop and i;m tryin to help her out
POLYTHING
Feb 16, 2007 04:13 PM
rutherford777
Jun 30, 2006 01:15 PM
ficodecko
Apr 17, 2006 02:17 PM
jwsimons
Oct 16, 2005 05:37 PM
R0ADN00b
Apr 22, 2005 01:51 AM
