Considering Nitrous
Old Sep 6, 2010 | 11:21 AM
joefigs's Avatar
Default Considering Nitrous
Hey guys I'm considering putting a nitrous kit in my 06 civic LX, mostly because my uncle gave me 2 25lbs nitrous bottles. I'm having trouble deciding whether to get a dry kit or a wet kit. Would a dry kit suffice for my car? I don't plan on abusing it.
Old Sep 7, 2010 | 08:49 PM
MBrent's Avatar
July 2010 ROTM
i had nitrous on my last civic. whats the rule? 50 shot or less, dry is ok? wet shot is def the way to go tho. that way u know u have the fuel to support it. when using a dry shot, ur ecu wont compensate for the nitrous and u run the risk of predetonation. if u detonate badly, bye bye piston. i dont know if ur car has a knock sensor to pull timing or not, so if u must use nitrous, use a wet shot (espescially if u dont plan on any ecu tuning).
Old Sep 7, 2010 | 10:02 PM
DaOne's Avatar
Mbrent what brand nitrous did you have?
Old Sep 8, 2010 | 09:48 AM
MBrent's Avatar
July 2010 ROTM
zex. 10lb bottle, purge solenoid, and it had the little metering computer on the firewall that squirts nitrous and fuel.
Old Sep 8, 2010 | 06:30 PM
i wish you would have let me run that car down the track one time before you got rid of it.
Old Sep 13, 2010 | 08:08 AM
kh022's Avatar
i heard this once...
Nitrous ...
is like a hot chick with an STD
you know u wanna tap it
but your scared of the consequences!!!!
Old Oct 9, 2010 | 07:11 PM
Mr Mobsta Man's Avatar
50 to 75 shot. Some people run a 100shot on stock 4 cylinders but I don't suggust that if your new to it. Other than the basic kit I would suggust getting a bottle heater and a pressure gauge. 91+ octane fuel.
*50 shot doesn't usually require any timing adjustment
stock or 1 step colder spark plugs
*75 shot generally requires 2* less timing.
1 or 2 step colder spark plugs
Learn how to read your plugs and do it after the first couple times you spray and make adjustments to fuel delivery and timing as required.
Old Oct 9, 2010 | 10:33 PM
theblackpearl's Avatar
don't do it, it will **** up your floorpan and scrape against the floor throwing sparks at you while you're in a one minute long drag race!!!!
Old Oct 10, 2010 | 01:14 AM
jprommel's Avatar
Angry Admin
danger to the manifold
domex
Feb 7, 2007 08:04 PM
weirddan455
Nov 17, 2006 12:39 PM
edyo74
Oct 15, 2006 09:39 PM
Flagheimer
Jun 8, 2006 08:38 PM
st1100pilot
Sep 19, 2005 07:26 AM
