dented oil pan
Old Sep 27, 2006 | 10:35 PM
ScoobyAddict14's Avatar
formerly aryiman98civic
Default dented oil pan
i found a tapped oil pan for a b16 ready for a turbo line, but its dented on the bottom. would you but it up for 30 bucks or just tap your own? i am lazy and i dont wanna go take it someone to get it done. let me know guys thanks
the guy also said there are no leaks and what not.
Old Sep 28, 2006 | 12:20 AM
slvcivic00's Avatar
Default RE: dented oil pan
How big is this dent? If its not that bad it may save you some time drilling/tapping and j-b welding a fitting to your oil pan.
Old Sep 28, 2006 | 09:41 AM
well the car it was on before was a slammed hatch, so you could only imagine the size of the dent. i think ill spend the money now to get my own oil pan tapped and drilled.
Old Sep 28, 2006 | 12:14 PM
ORIGINAL: aryiman98civic
^Good choice!
Old Sep 28, 2006 | 12:55 PM
AgentofDarkness's Avatar
ORIGINAL: slvcivic00
J-B weld? Whats up with that
Old Sep 28, 2006 | 01:00 PM
i had a friend use j-b weld and he hasnt had any problems with it. but i am going to find someone who can weld it up so i know its going to be secure.
Old Sep 28, 2006 | 02:18 PM
Are you going to have the fitting itself welded to the pan, or do what I did and have a bung welded on? If you're taking the latter, I'd start looking for a bung asap.
oilltd
Jun 10, 2008 04:06 PM
2X4
Mar 3, 2008 09:57 PM
dutch militia
Jan 19, 2007 11:19 PM
elfreaky70363
Jul 20, 2005 03:23 AM
