d17 boosted with plastic intake manifold
Old Sep 26, 2006 | 08:50 PM
02civcoupe's Avatar
Default d17 boosted with plastic intake manifold
ok I just realized my intake manifold is plastic is it possible to boost it and is it jus tas strong or weaker as a aluminum intake and why did they make them plastic
Old Sep 26, 2006 | 09:52 PM
StifflersMom's Avatar
Cat Fuсker
Default RE: d17 boosted with plastic intake manifold
Plastic is cheap...that's why it was made that way. Boosted engines run hotter. Heat + plastic = cracks. Cracks = debris in the intake runners and leaks. So it can be done, but ummm....
Old Sep 27, 2006 | 03:15 PM
Mr Mobsta Man's Avatar
dude hes talking about his stock airbox...that comes off when you install the turbo by charge piping from the intercooler (the aluminum pipe that your talking about.) You should do a lot more research before you turbo your car.
Old Sep 27, 2006 | 08:04 PM
02civcoupe's Avatar
lol no no boys my actual intake manifold is plastic only the d17 have them I was told it cna only handle 3 psi of boost I was wondering if tha tis true
Old Sep 27, 2006 | 08:26 PM
Pete's Avatar
The D17 engine is not the best D series to boost. You must alter the fuel system too. They have a returnless fuel system, you need to make it into one that will return. The internals are the weakest of the D series motors too, Im not saying its not possible to boost it, but its going to cost much more as opposed to a different D series engine.
Old Sep 27, 2006 | 09:10 PM
02civcoupe's Avatar
yeah i have been told that they need a fuel system upgrade. plus they need a sheet metal intake. wha tmake sthen weaker from other d-seriers engines?
Old Sep 27, 2006 | 09:22 PM
Chimera02EX's Avatar
don't feel bad, RSX K20 base engine has plastic IMs too.
Old Sep 27, 2006 | 09:37 PM
Cat Fuсker
sentra SER's have plastic intake manifold...guess how often they get engines replaced....
Old Sep 28, 2006 | 03:33 PM
you could probably buy an aftermarket metal one and replace the plastic one.
Vilex
Mar 4, 2008 06:08 PM
knoracing
May 1, 2007 12:30 AM
05BlueEX
May 13, 2006 12:15 PM
Chimera02EX
Dec 6, 2005 04:24 PM
Chimera02EX
Nov 7, 2005 09:53 PM
