Hey turbo guru's
Old Jul 13, 2005 | 06:05 PM
joepops's Avatar
Default Hey turbo guru's
Well as I have been reading through endless posts of turbo this and turbo that... I have some q's myself that I am not sure anyone has asked so far.
1. Life of a turbo? Life of your engine with a turbo installed?
Proper maintanence and installing the correct parts for what you want (single digit psi and above) is key but how long does a turbo last usually?
2. Installation and having it pass smog or C.A.R.B. procedures?
Depending on what customs, add on's or upgrades you do, do you lose other parts of your engine such as space for a/c, fans, or others?
3. Other car modifications
So now that you have your car turboed, what should be done elsewhere to furtherly enhance your cars performance such as suspension, clutch, braking system and what not?
4. Problems / troubleshooting with having a turbo? (had to ask)
Thanks guys!
Old Jul 13, 2005 | 09:06 PM
LEVIII's Avatar
Default RE: Hey turbo guru's
ORIGINAL: joepops
Thanks guys!
1. you should easily get at least 60k out of a turbo. Good thing about turbos is no matter what brakes it is replacable. Turbos break apart into peices with very little work and are fairly easy to rebuild/repair.
2. If you buy a carb legal kit it will be carb legal and fairly easy to install. Hardest part will most likely be the oil lines. Most peice together kits you will lose ac. You can usally add a FAL fan though.
3. why stop there. Deff get a good clutch, and brakes to handle the new power. An LSD would be a big boost in performance and suspension depends on what you want it for
4. Turbos are very simple devices but are noisy and can make other problems hard to find/locate
Old Jul 14, 2005 | 01:48 PM
joepops's Avatar
If any, which kits allow you to still have an a/c (its hot out here..) or would some customizing need to come into play? Yeah, what is an FAL fan?
Old Jul 14, 2005 | 01:51 PM
neon3kgt's Avatar
i think the edlebrock keeps the ac.
Old Jul 14, 2005 | 02:15 PM
Pete's Avatar
greddy keeps it
Old Jul 14, 2005 | 03:13 PM
joepops's Avatar
NICE!!! do any of you guys have your ride turbo'd? Man I love that sound! After install, what sort of exhaust should one place or do you guys have?
Old Jul 14, 2005 | 09:53 PM
LEVIII's Avatar
Greddy makes a great turbo exhaust for civics.
FAL = Flex a lite (I think) just its thinner
Old Jul 23, 2005 | 07:44 AM
Nail I3unny's Avatar
if a company has a turbo kit that takes out the A/C chances are they will have another kit that will keep it. (for track day car vs. dual duty car)
cumminspower
Feb 20, 2012 03:45 PM
mj91ef9
Jun 1, 2009 10:18 AM
Snakeater
Apr 7, 2008 09:55 AM
Stumasters
Nov 6, 2007 05:37 PM
kick7_honduh
Sep 2, 2007 05:19 PM
