Turbo w/nitrous
Old Jul 22, 2005 | 02:26 PM
CallawayCrazy3's Avatar
Default Turbo w/nitrous
I am buying a USDM b18c (GSR) engine off hmotorsonline.com. I was wondering if i were to run safe psi levels off a turbo, and i decided to get a Zex wet nitrous system would i have to do alot of internal work or none to run the engine safely?
Old Jul 22, 2005 | 02:56 PM
polo708's Avatar
Default RE: Turbo w/nitrous
to run boost and juice on top of a b18... definately stronger internals. The compression is high enough as it is stock... then you are throwing 2 strains on top of it... make it bulletproof man, make it bulletproof.
Old Jul 22, 2005 | 03:04 PM
ngoti 8tor's Avatar
Yeh, if you want that engine to last, definitely do some bottom-end work. Gonna be a saaaweeeeet engine tho!
Old Jul 22, 2005 | 03:05 PM
What would be some suggestions to make my internals bulletproof?
Old Jul 22, 2005 | 03:12 PM
Yeah thanks im getting that setup in about a month. Ill post pics of it when its all done.
Old Jul 22, 2005 | 08:42 PM
US3R!!!11one's Avatar
Why? Zex is horrible IMO.
Old Jul 22, 2005 | 10:21 PM
LEVIII's Avatar
Some forged stuff would be good. Do alot of research on what will fint your needs and budget.
Also, I think the best way t run N2O with a turbo is to get an RPM activated switch and only use it to help the turb spool faster.
Old Jul 22, 2005 | 10:44 PM
sacicons's Avatar
sleeve that motor, or you will die. or, umm, i mean, it will break. seriously, get it sleeved and put all forged internals in it with the cr a little lower, like 9.0:1
Old Jul 23, 2005 | 07:52 AM
Nail I3unny's Avatar
ORIGINAL: sacicons
haha wow why does that remind me of something my friend would say? lol
AEBS sleves are what i think we determined those sleves were in se7ens '60 PSI' thing...or at least i suggested that and he said it sounded right
umm thow a b16 head on there, racing rods, and low compression pistons and u'll prolly be set
Mayhem521
Aug 3, 2007 09:31 AM
TeamExodusPres
25
Apr 21, 2007 12:40 PM
thedougler
May 28, 2006 03:33 AM
STFUandrace
May 19, 2006 04:13 PM
civic x
27
Nov 3, 2005 10:41 PM
