horsepower gain
Old Apr 8, 2006 | 03:51 AM
jmiller8605's Avatar
Default horsepower gain
What kind of horsepower can I expect to get out of turboing my stock 99 ex.
Old Apr 8, 2006 | 04:05 AM
Kappa22's Avatar
Default RE: horsepower gain
Answers will be many and various on this, but I'd say you could run 200whp (maybe a bit more) safely on stock internals with a bitchin' tune.
Old Apr 8, 2006 | 04:10 AM
I am new to the tuner scene. What would be a good turbo to start off with and still be able to use the car as a daily driver? Would a super charger be a good option? I do like the sound of turbo's better.
Old Apr 8, 2006 | 04:20 AM
Kappa22's Avatar
It really depends on what you want. If you just want to keep the car as a solid daily driver with some more kick, you won't need anything serious. As for the supercharger vs. turbo question, it has been discussed incessantly around here, so I would search for some posts on it.
However, I'll summarize briefly:
If you want low-end grunt and pull from idle with a more tame, linear power curve, it's going to be a supercharger.
If you want more exponential gains coming higher up, it's going to be a turbo.
I'm not going to lie: I definitely favor turbos. Turbo-wise, you'd probably want to stick with something small to keep the spool time as low as possible. A DSM T-25 is a popular choice for mild Honda boost applications, since it spools ridiculously low (sub-3,000 rpm) and doesn't put out a lot of boost (good for daily-driver applications without a whole lot of extra parts, tuning, etc). However, it tends to start to run out of breath around 6,500 rpm. A DSM 14B is slightly larger, but can provide significantly more boost and has more breathing room. Nissan T-28's and GT-28's are harder to adapt to Honda applications (since they're primarily designed for longitudinal engine layouts) but when fitted, they make excellent gains and still spool below 3,500 rpm.
That's all I feel like writing right now... it's pretty late and I need to sleep. But I hope this gives you a few options to explore, and I'm sure there'll be plenty of other replies on this tomorrow.
Old Apr 8, 2006 | 10:59 AM
riceburner700's Avatar
check out the greddy kits, they are perfect for beginners who have no experiece with turbos. And they come with EVERYTHING YOU need and instructions/ step by step also i think...
Old Apr 8, 2006 | 11:12 AM
Yeah I was checking those out and that seems to be the case. Also, coming from a more muscle car backround, I kind of like the edelbrock turbo's, has anyone tried one of those?
Old Apr 8, 2006 | 11:16 AM
edelbrocks are really nice and have done there homework on there turbo kits, if you got the money i would get the edelbrock, but if money is tigher than i would go with the greddy kit.. Edelbrock will make a little bit more power than the greddy.... If you pay more than you are gonna get more hp with a kit that is..
jdizel
Dec 19, 2007 04:12 PM
steveabbott
Nov 23, 2007 11:04 AM
telecasteriv
Oct 21, 2006 10:57 AM
Forty04
May 5, 2005 08:05 PM
GSXF
Feb 18, 2005 12:51 PM
