Need turbo opinion quickly!!!
Old Apr 17, 2008 | 06:38 PM
croninc's Avatar
Default RE: Need turbo opinion quickly!!!
http://www.autozconcept.com/product_...oducts_id=5428
why so cheap??? seems like a legit site too
Old Apr 17, 2008 | 06:44 PM
LilMin's Avatar
ok once again thanks a lot and baron^^^^^^^^^ lots and lots of usefull info thanks a lot.............yah im trying my hardest to do as much research that my newbie brain can handle....im trying my hardest not to cheap out but still floating on the good deal/absolute **** line, and all your opinions and info help a lot one more question, anyone know how the greddy ecu piggyback e-manage ultimate works it runs about 500$ thanks again!!!!
Old Apr 17, 2008 | 06:48 PM
LilMin's Avatar
ORIGINAL: croninc
yah that is weird im sure someone on here has the answer to bad that wont fit my engine )at least i believe so
Old Apr 18, 2008 | 09:44 AM
GReddy_Civic's Avatar
Snail'n Admin
Its along the same lines as an ebay kit. Lilman, dont rush this, youll regret it.
Old Apr 18, 2008 | 09:45 AM
baron340's Avatar
why so set on emangle? from what i just read about the ultimate version, its a new update of emanage to compare with the f/ic, and you still have to buy the pressure harness seperate. the f/ic is a nice compact all inclusive unit with a built in pressure sensor. aem's list price is $464, you can get them cheaper from a variety of places. i know i'm prolly starting to sound like an ad campaign for dezod but theirs is listed at $414. if you can solder and have the time, then you're done and out the door for 80 bucks cheaper. or you can get the pnp harness for 125, and i highly recommend it. with the harness it took literally 15 minutes to install. so you're out the door for about 30 dollars more with a better unit, easier to deal with, and a pnp harness. by all means make your own decisions, thats just one guys opinion.
read this: info about f/ic and emanage, open loop v. closed loop and a few other tid bits
http://www.civicforums.com/forums/79...post-11-a.html
here is a guy that loves the ultimate, but isnt running a turbo, he is using it mainly for the rev and speed limiter stuff
http://www.civicforums.com/forums/79...its-alive.html
Old Apr 18, 2008 | 10:03 AM
LilMin's Avatar
o ok my fault baron i thought you were pushing for the standalone only (sloppy reading) ya that looks like a solid managment system for the money that definetly look like my bestoption ok well if all goes as planned im going with this kit http://www.dezod.com/pd_dezod_motorsports_version.cfm and the fi/c (AEM) and i will hopefully have it installed this month, i will be sure to post pictures/videos after complete, thanks a lot guys and for anymore tips PLEASE POST!!!!!!
Old Apr 18, 2008 | 07:29 PM
Snail'n Admin
wait you have a d17? hondas worst engine for mods. Do it right the first time, build it. Dont go with a piggy back unit. Theyre garbage and fool the ecu into thinking things. Use hondata or somethin of that sort
Old Apr 18, 2008 | 08:47 PM
Vilex's Avatar
ORIGINAL: GReddy_Civic
And I wouldn't even considering turboing a D17. You'd be better off swaping a K20a2 in there and turboing that. You'd get AMAZING results.. Sure, its kinda costy, but thats what you gotta do when you want serious performance.
Old Apr 19, 2008 | 09:05 AM
Snail'n Admin
yea, there was someone on here who built and boosted a d17 and made good numbers, just took time and money
Old Apr 19, 2008 | 09:22 AM
FlipHKD720's Avatar
https://www.hondacivicforum.com/m_456149/tm.htm
