Need turbo opinion quickly!!!
Old Apr 19, 2008 | 06:55 PM
  #21
baron340's Avatar
Default RE: Need turbo opinion quickly!!!
ok for all you 6th gen guys, yes the d17 sucks stock. but yes you can turbo it for some pretty amazing numbers. building the engine N/A does absolutely nothing. the cost v. gain is just too lop-sided. you pour money into it and dont really get much, butbuilding the motor after a turbo is a different story. the stock motor can handle 200 hp daily driven without a problem as long as its tuned well. a k swap, while by far the better performance option, is really really expensive. its around 5k for the parts alone not including the engine and trans or labor. my turbo parts pile is a boost gauge short of complete and i'm in it for $2372. my original plan was to swap, but geez 8k is a lot of money.
Dont go with a piggy back unit. Theyre garbage and fool the ecu into thinking things. Use hondata or somethin of that sort
surepiggy-backs arent as good as a stand-alone but they do work, and workwell if tuned properly. second hondata makes absolutely nothing for the d17. however they do make k-pro for the rsx and you can use an rsx ecu and get it converted to k-proand use it for the d17.
Old Apr 19, 2008 | 07:30 PM
  #22
LilMin's Avatar
im with stupid^^^^^JK but really i couldnt feel any different whats your whole set up son????
Old Apr 19, 2008 | 08:51 PM
  #23
GReddy_Civic's Avatar
Snail'n Admin
hey baron, learn to read, i didnt say t he d17 couldnt make numbers, i just said id do it right, that thread even proves it. Piggy backs are garbage, and nothing you can say is gonna make me think otherwise
Old Apr 20, 2008 | 04:54 AM
  #24
baron340's Avatar
and i never said you did say the d17 couldnt make numbers, but a few others were certainly implying it. you said build it first right. i'm just saying, you cant build the d17 right. if you build it n/a it isnt worth it. and you cant really build too much for turbo before you go turbo. you cant really do turbo cams and pistons and rods and stuff without the turbo, the engine will run funny. i'm also not saying stand-alones aren't better, but piggy-backs do work depending on the setup. i guess i should rephrase. if your long term goals are serious numbers, a full engine build, and a crazy turbo setup, then wait and get the ems or k-pro now so you dont waste money on a piggy back. but for a daily driven milder turbo setup, a piggy-back will work. sure not the best, but it will work.
i'm using pretty much a dezod kit with a few custom touches
Old Apr 20, 2008 | 08:16 AM
  #25
Snail'n Admin
dude, go look at that thread, he definitely built that d17 for boost
Old Apr 20, 2008 | 02:02 PM
  #26
baron340's Avatar
yes... he did... so its possible for it torun fine with turbo internals, my bad, i'm not perfect, but the point is still valid. it still costs thousands for all that engine building and the numbers dont really pan out till you turbo it to take advantage of all those shiny new parts. unless youknow beyond a shadow of a doubt that you aregoing to build your engine to that extent and go for over 300 horsepowerit isnt worth the money to build first. if you turbo it first you already have that extra hp, and you can decide to build it later if you want more hp. but enough arguing... sorry tojackyour thread.... good luckwith the turbo build
Stanley Man
May 2, 2013 05:07 AM
02Hatchback
May 6, 2010 05:04 PM
bluv4buckeyes
Dec 17, 2006 09:59 PM
Forty04
May 24, 2005 09:02 PM
DenkiEx
17
Feb 3, 2005 09:31 PM
