oil for turbo b16 (smoking blue on idle)
Old Aug 26, 2008 | 01:28 PM
tombakers's Avatar
Question oil for turbo b16 (smoking blue on idle)
hi, what grade oil are people using in there turbo b series motors i have been using 5w 40 fully syn and have now started smoking blue when on idle.
I spoke to my tuner earlier and he says to try a number of things to try and source the oil leak in ie the turbo or valve stem seals or pcv valve and he asked which oil im using at the mo and i told him 5W 40 and he then said that sounds thin for a turbo car..
He recommend putting a thicker oil anyway aside from the oil burning issue, this could also possibly solve the oil burning? he says 10w 60 or similar full syn
what you guys think?
Old Aug 30, 2008 | 09:52 PM
i've heard that 5w 30 full synthetic would be what you would use
Old Aug 31, 2008 | 06:14 AM
didder's Avatar
5w30 is whatcha need
Old Sep 2, 2008 | 12:26 PM
Mr Mobsta Man's Avatar
5w30
Do a dry/wet compression and leakdown test to find out where the smoke is coming from.
Old Sep 2, 2008 | 02:34 PM
bcrichguitars's Avatar
I use mobil 1 10w-30 synthetic in my turbo d15b vtec. Should i use 5w-30 instead?
Old Sep 2, 2008 | 02:45 PM
^+1, I agree.
Old Sep 2, 2008 | 04:01 PM
It depends on where you live. I guess no one ever reads their manuals?
Old Sep 2, 2008 | 04:27 PM
yea, 10W-30 is good above 20* F
5W-30 if it gets colder than that
i live in FL so i will always be using 10W-30
Old Sep 15, 2008 | 05:43 AM
last winter i ran 5w-30, but im parking it this winter. Thanks guys
Old Sep 16, 2008 | 08:31 AM
bcivic's Avatar
5w - 40 is fine thats not what your problem is. And if you live in a place that gets real cold and real hot at certain times of the year that would be better than 5w - 30 in that case as long as it is fully synthetic.
MikeD1980
Mar 7, 2011 02:49 PM
oilltd
Jun 10, 2008 04:06 PM
BuzzOrHowl
Jan 9, 2007 08:44 PM
DustindawinD
Sep 25, 2006 09:37 AM
