Shaft play?
I found this great deal on a t25 turbo, manifold, downpipe, and oil lines for my z6. The guy said the turbo has "minimal shaftplay". I know its bad but what does it mean and is it possible to fix it pretty cheap? Or should i just skip over the deal and find a better one?
Shaft play is pretty serious and not something you want to deal with. T25's are pretty tiny little turbos and dont cost very much normally. I wouldnt consider more than $100-$150 for that setup you mentioned to be a "great deal" so if its more than that I would stay away. You definatelydont wantrush into buying the actual turbo. You cancut corners a little morewhen you buy your intercooler and piping and other stuff but definately not your turbo.
nah, not TOO dumb of a question.
It's very simple actually, if you can move the "shaft" that the blades spin on, that is called shaft play. You literally put your finger on the shaft or blades, and try to wiggle it.
I was in my buddies Shed Doing things. Not gay things so dont be a ***. and i relized he has two Turbo wastegates and BOV's sittin right there. I thnik they were off of a VW. I was like Dude! Wicked!
didder
Oct 16, 2007 06:44 PM
nemesis08
Jul 19, 2005 03:21 AM
