stock ints. with turbo
Old Oct 12, 2005 | 06:06 PM
gunmetal's Avatar
Default stock ints. with turbo
I plan on putting a turbo on my 02' EX d17A2. It apppears that i can run about 6 psi. with stock internal saftely. But should I beef the ints. up to be on the safe side. If so, can I just do the top end or should I do top and bottom? Thanks.
Old Oct 12, 2005 | 06:16 PM
Pete's Avatar
Default RE: stock ints. with turbo
eh u dont really need to touch the internals. If u wanna be SAFE just get a thicker metal headgasket and some ARP headstuds. Stock internals are good for 200 whp
Old Oct 12, 2005 | 07:08 PM
ngoti 8tor's Avatar
ORIGINAL: gunmetal
To answer your question, yes, if you want to be safe, beef up your internals.
If you have the cash, do top and bottom internals, then you can run more than 6PSI.
Old Oct 12, 2005 | 08:17 PM
riceburner700's Avatar
just get some arp head studs and you should be good for low boost without any problems
Old Oct 12, 2005 | 08:24 PM
fast93civic's Avatar
With 6psi you will be fine, beefing up the internals would be neccesary if you wanna up the boost. You dont have to modify the topend either, but it would make a difference. And as for head studs, my mechanic said for 6psi it wont even be neccesary.
Old Oct 13, 2005 | 09:00 AM
Nail I3unny's Avatar
have fun finding bottom end for the D17
Old Oct 13, 2005 | 01:15 PM
ngoti 8tor's Avatar
ORIGINAL: fast93civic
How many guys do you know that get a turbo and never try it past 6PSI? It would drive me crazy not to even try it a few times past 6PSI.
Old Oct 13, 2005 | 02:23 PM
o4em2's Avatar
you can hit up to 10psi some even went higher, heres the site, all the internals for turbo these 2 specialise for d17a2.
www.dezod.com (under 7thgencivic on side menu)
www.truehonda.com (under em2 01+)
Old Oct 13, 2005 | 04:41 PM
neon3kgt's Avatar
the valvetrain should take allmost anything u got...
germancivic
Feb 4, 2008 11:03 AM
ballinboy1020
Oct 19, 2007 08:21 PM
cowsgonemadd3
Sep 13, 2007 04:28 PM
Powermidget
Jul 9, 2007 04:47 PM
