Tial 38mm wastegate Question
Old Sep 14, 2008 | 12:07 PM
Strong Island's Avatar
Default Tial 38mm wastegate Question
ok so i got a brand new tial 38mm wastegate, my question is, is that i am going to run the vac line to the compressor of the turbo.....cause my t3 already has the fitting on it, i read on H-T that if you run it to the compressor you will see like 2psi drop at the motor, so i have a 5psi spring in it now and i cant decide if i should get either
.70 bar/10.15psi which you if H-T is true would be like 8psi at the motor which i want! OR
.60 bar/8.70psi and if H-t is true would be like 6psi
I want around 8psi at the motor
can anyone let me know what they think thanks
Old Sep 15, 2008 | 07:12 PM
OR a boost controller?
nineteenninetynine
Apr 30, 2009 09:35 PM
didder
Sep 5, 2007 11:13 AM
didder
17
Aug 30, 2007 06:01 AM
sway2003
Dec 12, 2006 11:53 AM
Sleepin95CivicDX
Oct 15, 2006 09:12 PM
