Turbo for 98 LX??
Old Dec 9, 2005 | 01:26 PM
mikey Chalupa's Avatar
Default Turbo for 98 LX??
Is there a turbo kit for a 98 LX sedan or will I have to go custom. I have the NON-VTEC engine. If I have to go custom then what all do I need??[sm=smiley25.gif]
Old Dec 9, 2005 | 01:29 PM
Pete's Avatar
Default RE: Turbo for 98 LX??
Any turbo kit from 92-00 will fit your car, just as long as its for a D series motor. Im pretty sure they make kits for 98's, you would use the same turbo kit as someone with a VTEC engine.
Old Dec 9, 2005 | 02:22 PM
Marty's Avatar
The only thing that will not work is the intake charge piping. The 98 LX(which I have) has a vertical throttle body. I suggest swapping a 99/00 civic ex intake manifold from a automatic(all the plug in's are the same on the automatic intake manifold) on anyway because the Y7 intake manifold is very very restrictive. The reason no turbo kit is listed for your car is becaue the cat. converter is intergrated into the exhaust manifold and it will take removing or relocating it which by law is not supposed to be done. But you can buy a hi flow cat and put it inline like a 96-00 ex has to avoid any issues with this.
Old Dec 9, 2005 | 02:26 PM
Pete's Avatar
or not even run one, (not that id do that)
Old Dec 9, 2005 | 02:56 PM
Marty's Avatar
I have not ran a cat for years
soldout712
12
Oct 30, 2006 11:05 PM
eg9
May 22, 2006 04:43 PM
forrealb50
Mar 29, 2006 07:57 AM
TrailorParkPimp
Aug 28, 2004 12:21 PM
