turbo help newbie
Old Jan 1, 2009 | 04:05 PM
Cummins 429's Avatar
Default turbo help newbie
Hey guys howdy from a newbie here....
Got a few questions about my car here goes I'm not really sure how u guys identify your engines such as b16 or b18 or all this other stuff that i don't know what it is.... So heres what I got, 93 honda civic lx 4dr, the motor is a 1.5 16v... I'm a diesel tec and I build turbo systems for them and I got to thinking well hey maybe my car would do good with a turbo cam intake and an exaust, my problem is I need to know whitch engine I have (b16 b18 all that cr@p) and also what for problems normally arise from this type of setup with this paticular engine...
Old Jan 1, 2009 | 04:21 PM
You've got a D15B7 1.5 liter SOHC engine.
On Hondas, that engine code breaks down as follows: D series block, 1.5 liter (D15), B7 is the type of head. B7 is non-vtec.
http://en.wikipedia.org/wiki/Honda_d_engine#D15B7 That'll give you some basic info on the engine. Welcome to the forum.
Old Jan 1, 2009 | 04:27 PM
Thanks man I appreciat that. Oh does anybody know if I would be better off with just doing the cam or the turbo or should i do both???
Old Jan 1, 2009 | 04:33 PM
I found a really reasonably priced setup for the car on ebay http://cgi.ebay.com/ebaymotors/HONDA...Q5fAccessories I was just wondering how much boost I could run safely on my engine...
Old Jan 1, 2009 | 04:35 PM
I'm not sure if a D15b7 is a good platform to start on. Most of the guys on here with turbo setups used D16, B16, or B18 engines. I'm sure others would tell you to swap in an entirely different engine. It all depends on your goals.
And I've heard that you should NEVER use ebay turbo kits. Some parts in those kits are okay but others will fail very soon and destroy your engine.
Old Jan 1, 2009 | 04:46 PM
Well as far as "my goals" I'm not looking for massive hp I just need an extra 30 to 50 horse more than what it already has.. Its just a commuter and I just need a little more power cause I kinda got used to driving a 550 horse cummins around and now I got this little car so I can save on gas...
Old Jan 1, 2009 | 04:47 PM
Would it be possible to put a vtec head on this block????
Old Jan 1, 2009 | 05:20 PM
jprommel's Avatar
Angry Admin
yes, its called a mini me swap. and that swap should actually net you about the 30 extra hp youre looking for.
ps. look in the engine section i think they have how to do the swap in therer or something too lazy to look for u lol
Old Jan 1, 2009 | 05:37 PM
Thanks dude
Old Jan 1, 2009 | 05:53 PM
mini me swaps are fairly common and a pretty easy way to gain something like 20hp. Also, if you just want a gain of 30-50hp, I'm going to say a turbo setup is a little overkill. People usually shoot for 200whp minimum with a turbo kit.
I think a vtec head swap, a stage II cam (and full valvetrain if you can spare the cash), and an intake, header, and a cat-back exhaust should put you around a 50hp gain. If you want a little more power, you could add an aftermarket intake manifold, a bigger throttle body, and a high-flow cat.
