Turbo leaking oil
Old Jun 17, 2007 | 10:27 PM
red2000Si's Avatar
Default Turbo leaking oil
So I took my air filter off when I was doing my clutch install and I noticed a little bit of oil in the intake pipe. I then further inspected the situation and noticed a tiny little bit in my bov. Im trying to figure out what exactly is causing the problem. I have the greddy 18g turbo, manifold and downpipe whichis actually set up in kind of a wierd way so you can keep your a/c. The problem is, it makes it dificult to route your return line smoothly to the pan. Right now my return lineisnt really as straight and direct as it probably should be but I think its plenty good enough to drain the turbo. My question is, could my turbo be leaking cause its getting too much oil pressure(Maybe I need a restrictor)? Or could it be a combo of getting too much oilpressure and it not draining quite as well as it should? Has anyone ever heard of greddy turbos needing restrictors? If so, where did you find a restrictor that fit the greddy inlet fitting? Im going to re-tap a new oilpan this weekend and make my return line more direct. Hopefully the turbo seals havent been damaged too badly already!
Old Jun 18, 2007 | 02:21 PM
MY99SI's Avatar
Default RE: Turbo leaking oil
turbo compressor seal. i'de try a restrictor and see if that works. if it dosent then replace the turbo.
www.atpturbo.com has those blocks
Old Jun 18, 2007 | 04:25 PM
dfdon's Avatar
is it a greddy kit? if so i doubt its ur turbo try a restrictor
Old Jun 18, 2007 | 04:31 PM
ej6buddy's Avatar
restrictor will most likely fix it, just clean everything up and check for leaks while you're at it.
Old Jun 18, 2007 | 04:41 PM
StifflersMom's Avatar
Cat Fuсker
if the restrictor doesn't fix it look into reuilding the turbo. If you have any further questions about rebuilding it you can PM me.
Old Jun 18, 2007 | 09:28 PM
red2000Si's Avatar
Thanks for the help guys I'll let you know what ends up happening.
jaysdogjazz
13
Nov 21, 2015 09:07 PM
ic892003
20
Aug 21, 2008 03:40 PM
oilltd
Jun 10, 2008 04:06 PM
10isAce
Feb 21, 2007 09:19 PM
