Turbo my d16 with 96k miles?
New things have come to light and I decided that im going to do a total engine over haul. I found out there will be some money comming my and the guy that is going to help me do this said he could rebuild the engine. For this project I'm going to shoot for 250hp and try not to spend more than $3500. You think I can make that much power with that much money?
PS: I'm not going to start this project till late winter because there would be no point in doing all this stuff now and then having all that power go to waste driving the car in the snow. When I do start this project im going to post pics and I also might post the parts im going to use.
ORIGINAL: Forty04
How hard is it to just run the test and see what you're working with?? It takes 20 minutes in the driveway tops.....and its free
ORIGINAL: BurryTheSpeedo
would you honestly have to do a compression test though....waht if you just did a overhaul on the engine replacing everything you can like me....isnt that enough?? i mean i plan to basically rebuild both the block and head, so i can be ready for boost by the end of winter...
ORIGINAL: mr.w
One of the things the SHO guys replace first BEFORE boosting is the rod bearings. After many miles they wear. After you add boost, they wear more. Rod bearings aren't too difficult to replace and you'll give your motor more life.
Don't forget to break it in firstl
ORIGINAL: mxs
and I would hope that you would do a compression test after you rebuild the motor...
ORIGINAL: Forty04
Honestly, this is a simple concept. Compression and leakdown checks, when you get results either fix to get good results or go ahead and boost if you're satisfied.
I just ordered my turbo kit off ebay( don't worry I spent the extra money to get a good kit) its a greddy kit with e managment but no intercooler. I don't plan on putting this on till late winter so it will give me some time to find and intercooler, exhaust, downpipe, and maybe colder plugs. Oh yeah my engine is healthy so no worrys about low compression or anything, hopefully my engine doesn't blow up after I get this thing on.
ORIGINAL: mr.w
Also, ditch e-manage and get look for some real engine management. Chipped ecu + CROME ftw!
00IntegraLS
Oct 22, 2008 01:00 PM
fastrecklessracer
Dec 31, 2007 02:44 PM
LuckyCharm4x4
Jul 1, 2005 05:24 PM
