turbo setup suggestions
Old May 14, 2006 | 10:23 AM
98 EJ8's Avatar
Default turbo setup suggestions
alright so i just started working full time again for summer at midas muffler (im 17) and ive been doing some research trying to figure out a good turbo set up that i want to peice together myself for my 1998 honda civic Ex with d16y8 and stock internals and this is what my set up is so far, let me kno if im missing anything or if you have better suggestions on parts
SETUP:
Turbonetics T3 .42/.48
LoveFab Turbo manifold (AC MINI ME manifold)
Tial 38mm wastegate with .500 bar spring (about 7.5psi)
Custom 2.5 or 3" downpipe
Spearco Intercooler kit with charge piping (not sure about size yet)
Custom 2.5 or 3" exhaust (no cat) with HKS Carbon Ti muffler
HKS SSQV bov
OBD 2- 1 conversion with Hondata s200 or s300 ECU
Apexi SAFC 2
Greddy profec B spec 2 boost controller
Wideband system ( not sure what company)
A/f Ratio gauge, boost gauge, fuelpressure gauge
NEED HELP WITH:
choosing fuel pump
Choosing injectors
and anything else ive missed
help will be greatly appreciated
Old May 14, 2006 | 11:45 AM
riceburner700's Avatar
Default RE: turbo setup suggestions
wow you picked almost the exsact same set up i went with..... injectors i would go with a rc310cc
with the wastegate set a .5 bar you wont need a boost controller.. only need one if you are running like 15psi and want to adjust it to make the wastegate sound different... only REALLY need one internal wastegates
Old May 15, 2006 | 08:06 PM
MY99SI's Avatar
255 LPR Walbro pump
DSM 450's with a resistor box or like riceburner said set of RC's im getting a set of at least 700cc for mine
Old May 15, 2006 | 09:16 PM
allstock's Avatar
You wont need the SAFC if you are getting the Hondata system. The Hondata system does all of what the SAFC does and more.
Old May 16, 2006 | 03:11 PM
MY99SI's Avatar
true if you do convert to hondata it says to remove all electronic devices that can control the ecu :IE Vafc2 and so on
Old May 16, 2006 | 05:42 PM
98 EJ8's Avatar
thanks for the input, if any other people have suggestions let me kno i need as much help as possible, i have an auto tranny which will be swapped to a 5 speed sometime around this winter at the same time the turbo system will be installed, the reason for the Apexi Safc was so that i could use it while the hondata system was not installed and i would be able to putt around town (not romping on it) just to get me places until i can get the car dynoed and tuned and the hondata system all hooked up and functioning. im looking to get somewhere in the 200hp range with stock internals (yes im going to get a very good tune, nothing cheap)
THANKS
Old May 16, 2006 | 09:17 PM
gonna be shweet, you gonna get pics of the turbo installed step by step?
Old May 17, 2006 | 09:55 PM
98 EJ8's Avatar
yea ill do step by step pictures and ill post up pictures as i buy the parts, ill probly start buying parts sometime around mid july, starting with the turbo, if anybody knows of a good place to get the turbo let me kno, im ordering the manifold from lovefab and ill start goin from there, im debating whether or not to do the manual swap before the turbo or after
Old May 18, 2006 | 12:10 AM
thedougler's Avatar
I would have to say get it before, stick all the way, probably help to get all that power to the ground too.
Old May 21, 2006 | 04:38 PM
98 EJ8's Avatar
well i started looking for parts and cant seem to find a good turbo, i was going to go with a t3, .42/.48...but cant seem to find one, i want to get a brand new turbo, no used parts, any sugestions on turbo sizes using an external wastegate, it will be on a y8 with stock internals
thanks
BX_Civic
Apr 21, 2009 04:56 PM
Mistaashby12
15
Jul 16, 2008 11:30 PM
mattpker
May 17, 2008 01:54 PM
johnwohl
Jan 9, 2008 07:34 PM
97civicturbo
Jan 9, 2006 10:35 PM
