Turbo Talk(non honda)
Old Jan 29, 2006 | 05:19 PM
sacicons's Avatar
Default RE: Turbo Talk(non honda)
nice. all titanium pushrods and valves?
Old Jan 29, 2006 | 05:43 PM
Marty's Avatar
That is not what really makes the LT1's not rev freindly, the Cam is what really holds them back. The bottom ends are tolorable to the revs and with a brace connecting the main caps(adds to blocks stability), a cam, and mild headwork they can be seen w/o trouble. That is not my focus on this build though, I plan to be able to go to 7000rpm so that is a bit easier and if it goes right and I am making the power I want I'd say at around 6000 to 6500rpm you will be wanting to let off.
Old Jan 29, 2006 | 07:22 PM
sacicons's Avatar
well, with all that extra valvetrain mass, it would become a huge problem. but youre right, with a drag V8, youre much better off getting the extra power from displacement and boost than trying to rev it faster.
Old Jan 29, 2006 | 09:04 PM
Marty's Avatar
I will still have a good window for power, I am leaning towards a set of gt40's so they will spool early. I figure insted of a 4000 to 8000rpm power range I'll have 2500 or so to 6500rpm. Still the same amount just lower in the range. Set that up with a 3000rpm stall converter and I'm gold to come off the line in full boost.
Old Jan 29, 2006 | 10:01 PM
Kappa22's Avatar
Go with the GT40s. Parallel turbos are unmatched for sheer driveability, especially on something as big as an LT1.
Old Jan 29, 2006 | 10:37 PM
XCM828's Avatar
Not to mention they'll still be spooling 10 minutes after you race.
Old Feb 2, 2006 | 12:33 AM
polo708's Avatar
ever consider sequential turbos? A small turbine to bild boost quickly, then when its topped out it makes way for the large turbo in the top end. Takes a bit more tuning but when its done right its a monster.
Old Feb 2, 2006 | 12:43 AM
Kappa22's Avatar
Not as much potential as parallel though, and it's significantly more finnicky, especially when you're doing a V-setup. Plus, the small turbo/low spool is a pretty moot point on a V8. If you're running parallel, each exhaust bank simply routes through to a turbine, then the compressors both connect to the intake. But with sequential, you have to route both banks into a single small turbine, then into the larger one as well, not to mention all the gate piping.
Old Feb 2, 2006 | 11:45 AM
polo708's Avatar
ORIGINAL: Kappa22
My fault, just read the topic name again... thought we were talking 4-bangers
Old Feb 2, 2006 | 03:00 PM
Nail I3unny's Avatar
just a side question...would it be possible to have a quad-turbo setup in an fbody? like two sets of sequential turbos? so you get the power of two big turbos but it spools a lot faster.
